TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Set the trigger and values to the same port and connect the sig:)
i'm sorry but i still don't understand (still learning the basics of robotics)
if you've attempted this yourself, could you please send me a picture (as an example)
Bro. Deep breaths . Dont panic. Relax . Re-read instructions.
so i connect the black wire to where it says ground, red wire to where it says 5v and white wire to where it says signal?
if my understanding (above) is correct, how will i program it
Netherlands
Twitter YouTube
Yes, and in the ARC software, set the trigger and echo ports to the same digital pin, for example D0.
