Ultrasonic Collision Detection icon Ultrasonic Collision Detection — Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling. Try it →
PS3 Remote Connectivity
Hello I am a 13 years old and new to the EZ-B concept. Along with other things, I need to ask a few questions relating to joystick connectivity. I was ready to buy a wireless controller for the EZ-B and then realised that I could use one of my wireless PS3 remotes. I plugged it it using the charger cord and started up the ARC. When opening the joystick panel it registered the PS3 remote. I don't know what to do from here on and am unable to make it register me pressing the buttons. I will be really grateful if anyone knows how to make it work.
Thanks
Liam Graham
I think it may be because the lack of a correct driver for the PS3 remote. If I can't find one or turn on the remotes discovery mode I will just but a controller from Ebay. I found a pretty good $30 wirless one which I think I might buy.
I have installed a driver (How to use a PS3 Controller on the PC) unpacked it and have been able to operate buttons with it. But the buttons are in strange places and some don't even work. The buttons square, cross and circle (the three bottom circular buttons on the right hand side) don't work and triangle (the top button on the right hand side) is number 13 instead of 1. Also, are the servo sliders supposed to move when you press the correct button or move the joystick as mine do not? I may have been able to get the controller going but due to the mutiple problems I may just buy the controller from Ebay anyway.
The PS3 controller is not made for a computer, so I can't really tell you much about it. Sorry dude:)
Hi I use the PS3 controller with the EZB but it has to be plugged into a USB port to work and you need the motionjoy driver. I haven't seen yet a working Bluetooth (wireless) driver for the PS3 Joystick. It works great with a wired USB connection though just press the buttons in the EZB Joystick config panel and you can see what lights up and map it to a command. The joysticks won't be recognised though only the buttons
Good Luck hope this helps
If the joysticks don't work I may as well buy a wireless joystick from Ebay. I would much prefer to control the robot entirley from a joystick. But thanks anyway. You probably just saved me a lot of time.
The problem is finally resolved. I just recieved my joystick from E-bay and everything seems to be operating well.
#15
winstn60
so if i connect the ps3 controller to the pc, i cant use the joysticks?
boooooo
Hi Hoolagen1
It is possible to use a PS3 joystick with the EZ-B. It is simply rather difficult. You must first install a PS3 driver and then connect the joystick to the computer using the charger cord. But even if you are able to make it work there are still a number of difficulties. I would advise just buying a wireless joystick from E-Bay. I bought a Rapoo joystick, with which I have had no difficulties
