HTTP Server (Custom) icon HTTP Server (Custom) — HTTP server for ARC serving HTML/CSS/PNG/JPG from ARC/HTTP Server Root; supports AJAX tags (ez-move, ez-script, ez-camera) to control the robot. Try it →
I recently got the pan/tilt kit from the EZ-Store and I can't find the best/easiest way to attache the camera. I took off the attachment between the camera and the folding hook, but the holes do not line up.
Any help would be greatly appreciated,
disneythunder
Hot glue, zip ties, super glue, epoxy, velcro, carpet tape.
It all depends on if you want it removable.
You could also remove the camera from the casing, drill new holes in the casing and attach to the bracket with small nuts and bolts.
