Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Pandorabot New Url?
Pandorabot New Url?
I was trying to add pandorabot control and it seems like it no longer works and the old URL is not working. Looks like they switched over to playground URL which you can log in and create chatbot. Maybe the ez robot control just needs to be updated to reflect playground.pandorabots.com URL? Anybody have any luck getting this to work lately?
Very weird. Earlier, I even tried turning off firewall and connect, no luck. So I used my phone (AT&T) as a hotspot and boom...it connects. Maybe Comcast blacklisted the site? I don't know, but at least it works and I can play around with it a little for now. Thanks
Understood proteusy. That is why I was asking if anybody else was having problems accessing www.pandorabots.com. As it turns out the problem is unique to me as it is being caused by the Comcast router, if I connect the computer through my AT&T hotspot I access the website with no problem. Thanks for everybody's help since this is a Comcast issue consider this problem 100% solved:)
Hello
When I try to use ARC pandorabot control (i.e sending a request), I got a gateway error message:
Quote:
Error accessing Pandorabots: System.Net.WebException: the remote server returned an error : (503) incorrect Gateway. at System.Net.HttpRequest.GetResponse() at EZ_Builder.Common.GetWebResponse(MethodEnum method, String url) at EZ_Builder.UCForms.FormPandoraBots.eyI612D88X0(String, Single )
Remark: I have translated this error message in English as my Windows version is not in English.
When I try https://www.pandorabots.com/botmaster/en/home in a browser, I get the following error message:
Quote:
502 Bad Gateway nginx/1.1.19
My understanding is that pandorabot old url is no longer working.
Am I right? If yes, is it planned to update pandorabot control?
Thanks for your help.
EZ-Robot does not know the status of PandoraBot software or product direction. PandoraBot is a third party application. I recommend visiting Pandora Bot website and contacting them for support and/or company information.
@rreturea, I have just try the link, it is working:
Either their website came back in the meantime, either it is on your side...
#15
@fredebec. Thanks. It works also for me now. The url is back...
