I was wondering how to make the HB-25(H Bridge motor controller) from parallax to work with ez-robot could some one please help
thanks dustin
Sabertooth Kangaroo
— Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup.
thanks dustin
Hello dustin
You'll find the manual for the HB-25 here: https://www.parallax.com/Portals/0/Downloads/docs/prod/motors/HB-25MotorController-V1.2.pdf
The description within the manual explains how it works. Read the manual, and also follow the EZ-Robot Tutorial Section to understand more about Servos and Modified Servos, etc..
Simply connect the HB-25 to the EZ-B with a shared ground and servo/signal and you're off to the races
In ARC, use either the Modified servo Control (for one motor) or Modified Movement Panel (for two motors) - depends on your setup.
