ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
If by parralax ping you mean the ping sensor with the one ground, one positive and one signal pin it seems to work in ARC at least when I used the radar control.
Perhaps you can be so kind and give a little bit more background on the issue you are having?
Thanks
The parallax ping sensor works great with both the EZ-B v3 and EZ-B v4.
PING sensor does work (it did for me) you just set the Echo and Trigger pin to the same pin number.
To get more widgets, I too had that through and post that same question perhaps a year ago....why can't their be a built in interface to make your own widgets. Its probably not as practical to implement as it sounds. The scripting options built in are rather robust and I've had success making external .NET apps with the aid of the SKD for things the ARC does not perform the way I want or need.
Welcome to the group, BTW!
My mistake. The ping sensor I tried to use was bad. soon as I swapped it out for another worked fine.
Great to hear Droid!
