Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
Peaking Under The Hood Of My V4 Ezb
Hi all,
I just unpacked ny new V4 EZB and thought I'd shoot a video of what it looks loke up close and with all the plastic caseing taken off. I wanted to get ths posted last night but Youtube took forever to up load. Enjoy:
Thanks Dave!
I don't know much about it myself since I don't have mine in my hands yet but to answer some of your questions;
The 3 ports you said you don't know what they are, I believe these are the three I2C ports. The black one to the side I assume is the UART port.
DJ has previously mentioned it's centre positive on the jack, just to confirm what you said.
I'd say it's a 20A fuse, the EZ-B passes through the voltage so chances are you may want to pull a lot of current. A 20A fuse will still blow very quickly if there is a problem. As far as I am aware a fuse is a fuse, an amp is an amp regardless of country.
It's 3.3v on the ADC/I2C ports.
Love how it looks, so neat! And my concerns about it's height are put to rest, I didn't realise it was the power base in the photo I saw of it. Since I plan to not use the base and just have a mini deans connector in my robot it should just plug right in and be that bit shallower.
Thanks for adding your knowledge to the statments I made and the questions I asked Rich. Glad it was of some help and enjoyent to you. ;)
Instead of another EZB4 thread I'll just add a couple of more pictures into Daves' post. I did take one EZB4 apart, moved the large capacitor (resettable fuse) up a little, desoldered the power connector and added a couple of power leads to help relocate the way power can be connected. Don't forget to add fused protection between the EZB4 and your battery source.
Guys... nice, thanks... And Dave... LOL...We use the same fuses and such as you Yanks do... Nothing special here... That is indeed a run-of-the-mill 20amp fuse...
Richard
Thanks guy's for taking the time to share video and pictures.
:):):):) j
Ok, I am jealous, where the heck is mine? It's floating around in some factory in China :-
Another thing to keep in mind is the speaker is a spring loaded contact design integrated into the plastic housing. No housing, no speaker.
I'm sure one could solder wires and add an external speaker if required.
@Lumpy, I'm sure all the modifications to the board will slowly come once people get hold of theirs and start adapting them to suit their needs:)
