Read Digital icon Read Digital — Read TTL digital input from an ARC I/O port; real-time red/green status for low (0V) or high (+3.3/5V), selectable board/port and read interval. Try it →
Wifi foremost.... However if you use a level converter you might connect via serial but not for the purpose of controlling the EZB4.... Why do you need to? Wifi is so much more convenient...
I'd like to know if this is possible also. Deuel, thanks for asking the question.
        Chris
It is possible, but as I said not for the purpose of controlling the ezb4... You can connect one of the UART ports or digital pins (with a rs232 level shifter) to your PC to read and write data... Not sure why you would want to, however... A better use would be to connect your EZB4 to an arduino....
WFI is really the only way to connect an ezb4 to your PC or tablet
With the V3, you could pull the Bluetooth chip and replace it with a USB to TTL connector, but the data rate on the V4 is far too fast for serial TTL.
It is theoretically possible to replace the WiFi with an Ethernet connection, but I have no idea what parts to use or if it is physically possible.
Perhaps something for the wishlist for the next generation EZ-B for those of us building robots with embedded computers.
Alan is correct, there is no way to connect the ez-b v4 directly to your PC because the communication is too fast for Serial. We considered adding USB, but that would have made the EZ-B larger - and no one wants that.
My reason is simple, embedded computer, and my robot is all metal. I attribute most of my disconnects to the fact that it is all metal. The ezb4 is mounted in the head at the uppermost part of the bot, surrounded by aluminum sides and bottom with a custom plastic see through cover. Still waiting to try new router/ cable modem to see if it helps. Before everyone asks, it disconnects in both modes, AP mode and client mode.
                                                        Chris
A metal robot will make the ez-b v4 wifi unhappy and disconnect, unless your embedded computer has a wifi dongle - because how else would you connect to the embedded computer?:)
So, since your embedding a computer in the robot - put a wifi dongle on that embedded computer and you will not have disconnects because the embedded computer will be beside the ez-b within the metal chassis.
There is no reason for slow and bulky wires - someday it'll be nice when our servos are wireless as well:D
@DJ... Wireless servos?... Ok, now we're talking. That would be a huge and welcomed advancement....:P
