EZ Chart icon EZ Chart — 4-series bar chart for real-time sensor comparison in ARC; set titles, values, RGB bar colors and conditional coloring via EZ-Script. Try it →
Servos will always make noise, because they are servos. When a servo holds weight, it vibrates back and forth to maintain the servo position. The vibrating of the gears internally will make noise. The Learn section has a tutorial on the servo.
The servos are not 2nd grade, and have metal internals. The servos are entirely metal geared and with metal bearings.
As the tutorial in the Learn section implies, all servos will make a buzzing noise when holding weight. If you would like more information about how a servo works, let me know and we can get into the technical details:)
The sound of your speaker is not correct. It sounds as if the EZ-B has a malfunction during assembly. As Jeremie has stated, please Contact Us and use the Warranty category - provide a link to the this thread so it can be referenced.
In the meantime, Google will be your friend to find out more information about servos to learn what robots are built with and how they move. The difference between a "servo" and a "motor" is that a servo is a motor with additional hardware for gearing torque and electronics to specify output shaft positioning. A quick search returned this write-up, which also explains the two different noises that you will hear from Digital and Analog servos: https://www.rcmodelreviews.com/howservoswork02.shtml
We also have a lengthy write-up about what a servo is on our Learn section, which you can view here: https://synthiam.com/Tutorials/Lesson/48?courseId=1
Feel free to explore the learn section of this website - we have a very detailed learn section with great deal of information to turn you into a robot expert:)
Germany
I am not unused to servos.The thing I wonder about is, that the neck servo keeps making noise, even when he doesnt hold any weight. (Not connected to head or torso. Just laying on the desk.)
The metal gearing in the servo adds a little more tension than the plastic gears that most are used to. The vibrating is because the servo is moving between positions - and the gearing is tight, so it may vibrate. If it's super annoying and bothering you, send it to us and we'll send you a replacement:)
I spent nearly 2 weeks in China sourcing servo manufacturers for our platform. The goal was best quality for lowest price. The servos we found are actually modified specifically for us to use 7.4v batteries, and a few other changes... such as wiring and gearing.
i notest that noisie servo's when you use them several houres, the noise go's down almost you dont hear it.
Germany
Found the error. Black cable is loose inside the connector socket. -> servo moves -> cable moves -> connection gets lost for a brief moment.
Had the chance to test the camera with an other ez-b. Same error: "ezbv4 camera image render error: System.ArgumentException: Ungultiger Parameter. bei System.Drawing.Bitmap..ctor(Stream stream) bei EZ_B.Camera.(Byte[] ) bei EZ_B.EZBv4Video.()"
Germany
Thanks for all the help:) I will contact the customer Support for a warranty replacement.
