EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
Personality Gen
Is there a variable that shows the stations of the personality gen. ? See I want to turn the personality gen on and off or pause ON or OFF according to a variable. What I did not want to do is have the personality gen already on then turn off the pause, that may restart the personality gen. and reset the timing on it.
I'm now using the ON / OFF for the personality gen. Seems to work fine.
I am not sure if this is what you found but I use the code:
ControlCommand( "Personality Generator", pauseOn ) ControlCommand( "Personality Generator", pauseOff )
in my code to activate or stop the personality generator without having to physically check or uncheck the box. Also there is a gear button on the personality generator panel that will allow you to pause the scripts while the robot is moving forward etc.
Aaron
