EZB Connections— Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.Try it →
what i mean is the version 2 wire conection.you can switsh them and there,
is no pic how the wire is correct connected.white on the left or right side.
Oh, please connect the black wire to the right side, if you look very closely you can see the label 'GND' which stands for ground and is the black wire connection.
Sorry for the late response @Nomad
Here you go:
hi jeremie
what i mean is the version 2 wire conection.you can switsh them and there, is no pic how the wire is correct connected.white on the left or right side.
thanks
ah yes .the more easier,the more diff is for me ,lol thanks.
