Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Pimoroni Pan And Tilt HAT For Rpi 3 B+
hi
i just purchased the pan tilt hat. i know it works because i tried the python examples.
But how can i get ARC to recognize it?
I do have the ez server installed on the rpi with a camera, it connects, i tried the camera control example and the video works. i added the vertical servo, tried to set it up as D0, D1 and D2. neither will control the pan and tilt hat. i believe the pan and tilt works of of i2C but i am not certain.
information on the pan and tilt hat can be found at https://pimoroni.com/pantilthat
please help, Thank you in advance.
Raspberry Pi by Pi Foundation
Synthiam ARCx runs natively on Raspberry Pi 4/5, controlling robots via browser with EZB controllers, vision, speech and scripting.
Servos ✕
ADC ✕
Digital ✕
Vertical Servo by Synthiam
Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos.
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
Real-time servo position input via Arduino ADC over I2C; supports Nano (6 channels) or Mega (16), configurable I2C address and scalable chaining.
#26
OMG the servos are working.
but now i dont have any video anymore from the rpi camera. the port use to be 24 now its 10024
Check my instructions you need to click the antenna in the camera control.
you should see the camera feed or fake image with a counter.
please recheck and let me know the results.
#28
i see a fake image with a counter
#29
the camera works when i start the server this way: sudo nohup mono ./EZBPi.exe. obviously the servos dont.
#30   — Edited
You didnt answer my question when you change the port to 10024 do you see the camera feed or a fake image. please follow/read my instructions for version 1 of BlueBerry Server.
#31
i do see a fake image with a counter. i selected the camera by pressing the antenna button in the camera control
#32
pi@saripi:~/BlueberryServer/Blueberry.Server.Python $ python3 Main.py 1101-root-INFO-Starting... platform=linux hostname=saripi 1101-DeviceI2CController-1-21-DEBUG-write: bytearray(b'\x00\x08') 1101-EZBTcpServer-DEBUG-starting up on ('', 10023) 1101-EZBTcpServer-DEBUG-waiting for a connection 1101-EZBTcpServerUdpBroadcaster-DEBUG-Starting port=4242 1101-EZBTcpServerUdpBroadcaster-DEBUG-running.... 1101-EZBTcpServerUdpBroadcaster-DEBUG-broadcaster ip4 addresses found:['192.168.8.239'] 1101-EZBCameraUdpBroadcaster-DEBUG-Starting port=4242 1101-EZBCameraUdpBroadcaster-DEBUG-running.... 1101-EZBCameraUdpBroadcaster-DEBUG-broadcaster ip4 addresses found:['192.168.8.239'] 1101-FakeCameraController-DEBUG-running thread:Thread-4 1101-EZBCameraTcpServer-DEBUG-starting up on ('', 10024) 1101-EZBCameraTcpServer-DEBUG-waiting for a connection ===> Press Enter to quit...
