My sensor only has a Vcc, Gnd and Signal pin on it, can i wire it with just 1 servo wire?
— Edited
Some people from that shipment have just received theirs yesterday. I have no idea what happened with that shipment, normally it only takes a few days
From the people who received theirs yesterday, where there any that live in holland?
And i know what happened to the shipment, it was sent by boat in stead of airmail.
FINALLY got my EZ-B after 5,5 weeks
Yes! it works, if you have a 3 pin ping))) sensor, you need to make the trigger and response port the same and it will work with 250 delay!
on the maxsonar you can hook it up as HC-SR04 OR SRF04 USING ECHO AND TRIGGER ON THE MAXSONAR TRIGGER IS RX PIN AND ECHO IS THE PW PIN no conversion is needed like in analog mode,also analog mode jumps aroung alot and not always steady and its great for robot eyes dual ultrasonic sensors dont fit well in most robotic toys eyes but a single transmitt and receive ultrasonic sonar can
another thing about using the maxsonar it using very low current ,not like the hc-sr04 or parallax does ,2ma compare to 30-35ma on parallax ping so battery will last a lot longer cost it lower too $25 compare to $30
