Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
Hey guys, best way to plastic weld is friction welding, you get a piece of the same kind of material, put it in the tip of a high speed drill or dremel tool and use friction welding to bond parts, always do the inside first as you can make a much cleaner repair.
