Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
I keep reading about this regulator or lack of regulator problem. Maybe im missing something but I was planning on powering my ezb through the BEC function of my H-Bridge. So in other words if I'm powering my H-Bridge with a 12v sla battery and use its bec function the ezb will only receive 5 volts thus the sensors would only have 5 volts correct? Are most people not using some type of H-Bridge? Chris
@kamaroman68 If the EZB4 board work on 5V... 5V Camera and wifi too?... I thought the board had a min voltage input of something like 6V (or 7.2v)... Are you sure 5V won't cause brown outs? And how much power can the bec on your H-Bridge supply, though? My 2 x 12 Sabertooth motor control can only supply about 1amp through it's bec.... and it's way more powerful than a basic H-bridge...
I would be causious about using that setup.
