User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
did you try other like check or slider.are the batteries fully charge. try whit remote
It may sound stupid but are you connected to the Brookstone Rover via WiFi before you hit connect on the movement panel?
@Rich yes i connected to the rover's router network beforehand...
you can also try.remove the connection,reboot and connect again.
@nomad18.08 thats the first thing i tried...
so it connects the rover.updates ARC or pc .keyboard settings.
Wachtos when I was setting my rover up the thing I missed was the little box in the lower left hand corner. (gear)DJ said gear but on my laptop you can barely see a gear in the box. There are some settings in there you need to set. I have a v1 Brookstone rover
