Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Ecuador
you have to have some ideas about programming... first read some books or tutorial about C#.. and then you will be able to use the SDK:) good luck! i recommend you to use only ARC
