TCP Client icon TCP Client — Telnet-like ASCII TCP client for ARC: connect to IP:port, send ASCII, view raw or HEX server responses with local echo Try it →
Plugin And Connection
To the ezb family I'm having issues on the bioloid premium robot dynamixel controller plugin and wi-fi connection. I have both ezb controllers the tiny and the 4 the 1st generation. I have a important project do, and will be graduating soon and robotics is my minor. I need some help please, thank you Mike.
Good morning DJ, I'm using the ezb4/2 controller, and following on learn, but no movements with the dynamixel. Everything else is ok, and also I'm using a adapter hub that has all of the dynamixel plugs in it. I'm on school break from college, so I couldn't work on this project. I want to learn the software because my degree is in teaching and I've been into robots since the 6th grade.
Hello DJ, sorry to bother you but can you make a video on the Dynamixel servos acting with the ezb4 please, thanks.
Every time I work on my bot the servos don't move, so I thinking to myself that everything is ok, but maybe I'm doing something wrong. So Mr. Sures that's why I'm asking you would you be kind enough to do a video on the Dynamixel sir.
