Frequency Detector icon Frequency Detector — Detect audio frequencies via PC microphone (FFT), output a variable and drive servos within configurable min/max ranges with waveform feedback. Try it →
Turns out i forgot to save it in ARC. The code was there, but no button to use it. Haha
I have added the Change i2c utility for the next version of ARC - which will be this evening.
dj you work fast as lightning.
thank you.
where can i find the adres of a rgb ? standard is 0xA0
problem when i take a second rgb window and try to change the adres,the , ezbv4 disconnect.i wanted to use two rgb as tail lights on roli.
this was an old topic.but solved.
thank rich
i made victory to early.you can change the adres.but here's a problem. best to use one rgb at the time to change an adres.taking a second one, causes a problem,you need to close and reopen ARC to validate the adres. so you need to save your project with two rgb els the ezbv4 goed into lock up. and thats when ezb or rgb gets confused.it works for about 45 min, then one rgb goes out.then you need to start from the beginning, to get bolt of them working again.with original adres.
