Hugging Face icon Hugging Face — Connects your robot camera to Hugging Face AI models for vision chat, object tracking, classification, captioning, and autonomous movement. Try it →
makes sense to me.. before i print those parts ill see about modifying them the way you describe. I was going to try designing a little less neck maybe stick the servo just a bit further into his head
Thanks, his head works great - there is no engineering flaw. He can look left and right while looking down without any issues. Once you have a replacement servo, you will enjoy JD lots:)
hi luis
that part called #8 and will availeble in the fall.
IM not sure i know what you mean nomad?
DJ . I will drop the subject until i can fully work with him , I send a message to the staff to go a head and send replacements out. So I should be able to fully explore.
luis
part #8 is the little one where the arms hang on.
haha ok .. i got it now. thanks for the update.
I don't see what difference it would make if the pan servo is above or below the tilt servo (i.e. the current JD design vs @Luis idea). I played with both ways and the difference was minimal.
As for "gimbal lock", unless I am mistaken it only applies to 3 degrees of freedom, JD's neck only has 2 degrees of freedom. There is no way for the axis of two of the three gimbals to run parallel as there are not three axis...
you are right Rich. I used the wrong term when I said gimbal lock.
But I have found ocr and camera reads work better when the cam is as stright up as possible.
If i look to the right and down the camera angel is better than 45 degrees .
the way i was looking at it , would leave the camera in a more upright possession and not look like he was laying down.
I am really interested in JD's ability to see what is around him order to interact. I will wait further judgment on this until i have actually tested in the real world as of now i have been holding the camera at the angle dj head will tilt and found that reading many type of codes had a much higher failure rate at an angle than it did upright.
