Good Evening!
I see the saywait command. I like it! I see the Sayezb command. @DJ could you create a sayezbwait command?
Thanks, Wayne
Ez Line Chart
— 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control
Good Evening!
Thanks, Wayne
For a work around, use this command in a separate script to cue the saying script:
It will then cue this script:
Here's an example that uses this. sayezbwait.EZB
@technopro: Thank You for the repsonse! I will use that in the meantime. I guess I should of made this thread needed help or some other thread type. I was really hoping the programmers at Ez-robot would see this and add this command. I really don't know how hard it would be, but it would be nice!
Thanks again!
I'm sure DJ will pick this up and, if it's possible, will add it to the to-do list.
Ironically, this item has been on my to-do list for a while
I do not have an eta, as there are many other items ahead of it... but i'm certain it'll be done for ya
