Single Camera Servo Server icon Single Camera Servo Server — TCP video server for Unity clients to stream camera video and send servo positions to ARC for remote robot control Try it →
Hi Stiko. I use a switching power supply 6-12v 5000mA that i had for my rc charger and i have set it at 7.5V. The model is MW7H50GS if you want to make a google search. Your English are much better than mine!:)
Germany
Thanks for your friendly and fast answer. Can you show me a picture of the adapter to the Lipoakku plug? The pole coverage interests me. Is the battery disconnected from the system during this time? Or have you installed a changeover switch?
Thanks a lot of.
I must apologize for not reading correctly your post. I gave you a solution to power up your EZ-B stand alone. It possible to power up your robot by power supply but you must do some mods at the electrical circuit inside the main body (battery case). As i don't have the original jd robot (mine is 3d printed) if you can post a photo of the body inside i will give you the way to make the modification. Don't forget that you must have some basic soldering skills.
If you open the body, all you need to do is disconnect the adapter from the ez-b and connect the power supply to it. I dont think there is any issues.
You must use a 3 pole dc female jack so when you connect the power supply, your battery will disconnect from circuit. Then when you unplug the power supply you can use the battery to power up the robot.
The way MazeHorizonTech describe is the easiest but you don't have the choice to use your battery.
Yes, if you want to be able to remove the plug and quickly change to battery power, you need a dc jack that interrupts the battery and allows the power supply to flow. That could require some modification.
I don't believe a 5000 mAh supply is sufficient for a JD due to the inrush current when a bunch of servos start to move. You will want a 20 amp supply or you will get brownouts. You can also help prevent brownouts, possibly staying with a lower cost 5 amp supply by doing the "super-cap" modification.
See post 15 of this thread: https://synthiam.com/Community/Questions/8686&page=2
There are a number of threads on the forum with recommendations for power supplies. I suggest searching on the term "inrush" rather than power supply for better results since the issue being solved is inrush current.
