Wowwee Rovio icon Wowwee Rovio — Movement panel integrating WowWee Rovio with Synthiam ARC for remote drive, live camera, audio and docking control. Under development. Try it →
no only a little black line appear below under taskbar
If you launch notepad, you have the same issue in that application, correct?
i set resolution lower ,then i have this.
thank you RR
d-cohran your wright same in notepad
set your resolution back.
If you launch notepad, you have the same issue in that application, correct? what is the brand and model of your monitor? I will see if there is a resync or auto picture adjustment in the menu or anything like that.
#16
do you know the model number of the HP? I am going to look online for the menu options.
