Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Doc... Thanks... That was awesome... you lucky dog you...:)
Excellent:)
As someone else stated in another post (Dave I think), it certainly looks taller than I imagined.
Does it say that message everytime the unit is powered up? Chris
I believe you can change it (this is based on old videos from DJ)
Yes, each time power is applied, the boot-up is the same.
EDIT: Once an actual connection is established with the EZB4 then there are no more verbal messages heard unless the EZB4 is reset.
No, the message is only spoken on boot-up until a connection from ARC is established. It won't happen again until it is reset with the hardware reset button
