Recorder icon Recorder — Record and replay EZB communications (servo & digital commands) with forward/reverse playback, save recordings and trigger them from scripts Try it →
Pretty Soon Will Doing Some Sensor Testing With Data
I was hopping to use the sensor testing bench i have at work,but work wont let me :( but i will be making one or buying one
One i get it will be doing SONAR testing first ,detecting materials and different types of sonars and corner wall detecting ,witch is fairly hard with most sonars you have 3 points ,where the walls meet and each side of the wall for very good navigation you need where the walls meet. from each 4 corners you can make a good navigation map (xy)
ANOTHER test is testing different sonars and comparing them,i think my new digital scope has a way to do graphs or waveforms and save them
Next is IR sensors
Okay, that's perfect! I was looking at them on eBay the other evening and I just wasn't sure is that was the best way to measure current. Should I measure volts too or would that remain constant?
Do you have an opinion on vibration sensors? If I wanted to detect some one walking near my robot it that possible?
Vibration there are many types ,proximity.capactive,motion,and vibration sensor. All do about the same. Motion is for people distance,capactive types are for close touching ,also vibration are the same. A good motion sensor is PIR part # AMN22111 ,very small fairly low cost ,great people detector And they make them with analog or digital output ,made by panasonic what good about them then other types of PIR sensors are very tiny,very easy to mount
On current sensor dont really need to detect voltage,it remains constant till current level drops too low.
Cool. I've got the PIR sensors, no probs. I just bought a vibration sensor:
Black Vibration Sensor
Just wan't sure how sensitive it was. Guess I'll find out when I get it. I've been looking at the spark fun peizo vibration sensors. I wanted one that was super sensitive and another one that would be much less. I was hoping to be able to detect someone walking downstairs and some one walking twords the robot.
Just curious robotmaker what software do you use to measure the time vs signal level results from your testing?
Vibration sensors are hard to use,since the robot is moving and any false moves will trigger the sensor. What a vibration sensor is a 2 pins and sometimes a ball touches the contacts.
Some use too use mercury,best type of vibration sensor is a adjustable type second on vibration you need to bump in to the robot to set if off
PEIZO types are about the same you need it to be very close to the robot (touching)
Vibration sensor is when you bump in to the robot and make it vibrate
On piezo and capactance types it very close touching
Proximity are made for longer distance like PIR TYPES,but are hard to make ,and mostly RFI TYPES SO THEY DO HAVE PROBLEMS
There is no software i use,mostly is a distance meter in inches for ping type sensors one i got was from china, any type of sonar with PING and ECHO ouputs can be used it has a microprocessor and lcd display plus calibrated optical bench with a ruler I was going to make one using a arduino and lcd for stability ,i use a scope will look for the link on the distance meter from CHINA
