Camera NMS Pose icon Camera NMS Pose — Overhead camera tracks a glyph to give precise robot pose to ARC's NMS for multi-camera indoor/outdoor navigation and waypoint control Try it →
Printing & Using The Pwm Value ? ?
Good Morning EZ-Scripters !
 Attached is my crude attempt to use and display the PWM Value.
:Start
PWM(D19,50)
:Loop
$x=GetServo(D19)
#WaitForChange($x)
Print($x)
Goto(Loop)
 PWM(D19,50) initializes to 50%, and the Slide Bar changes its value, but my Print Value does not change ?
Thank You All & Best Wishes,
[email protected], 602-246-1246(H)
RoombaSpeedControlUsingEZ-B'sPWM1-Feb-2013.EZB
When you set port D19 to PWM, it is not a servo, it is PWM.
PWM = Pulse Width Modulation SERVO = A device used to provide control of a desired operation through the use of feedback
Every control has ? next to the X (close). If you press the ?, you will be directed to a tutorial page for that control. I suggest viewing the PWM control tutorial and watching the video. It explains a little of what PWM is. PWM will not work with the Roomba. The roomba speed is controlled by SetSpeed() and GetSpeed().
The EZ-Script manual is next to the editor.
Good Morning DJ !
 Thank You for both your Tutoring and your Patience with the aged.
 Your PWM Video is GREAT !
 Cleaver how you used a Single Ribbon Cable from multiple EZ-B Ports to the H-Bridge.
 It's now on to GetSpeed() & SetSpeed() !
SetSpeed( speed ) Sets the global Movement Speed value Example: SetSpeed(50)
GetSpeed( ) Returns the global Movement Speed value Example: GetSpeed()
Thanks Again,
:) Anytime Doug!
It means a lot to me when I see someone find the solution with a little guidance - rather than doing all the work. Kudos!
