UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Problem With If
Problem With If
I was trying to script with an "if" command and in the script functions it says if (adc[port])[condiction][value]) in the sample it says if(adc(adc2)>50) and leaves out the value the text says that the value is a user defined integer Can someone give me a correct example and explain what the interger is or represents?
Put a space between parameters (Between adc(adc) and > and 50)
if (adc(adc2) > 50)
Thanks!! and happy holidays!
