Horizontal Servo icon Horizontal Servo — Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert. Try it →
i'm having speech recognition problems too, sometimes it works and sometimes it doesnt. seems never to understand "right" and i'm changing microphone setting on different numbers to experiment. i'm saying loud and soft, also changing my accent to be like i'm from canada and not working! anyway what order do we connect things? we plug in servos, then open speech recognition, then config,
or open speech, config, then plug up servos?
I wouldn't think that that would have an effect.
Checking into it
I can't seem to replicate the issue you are having. Are you sure the mic isn't too high? Or too low?
I have mine set at:
It definitely is not the mic. I load the program and it does not work. I delete the control and replace it with a new one and presto, it works with all mic commands writen on the screen. Very perplexing. PS My mic is set the same.
This new version may have done it. I just tried loading anew twice and it works fine.
DJ i have some ideas you may want to add to the next version, where can i email some ideas?
support at ez robot;)
