Microphone icon Microphone — Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback. Try it →
Problems I Found Using Windows 7
all windows 7 is a hype ploy for you to upgrade to another operating system i found its not as fast as windows xp pro ,running on the same machine with same software,memery,i check hard drive speed test,and reasorces was at 50 to 60% compare too 10 to 20% now using 64 bit processor it was very fast more bits processing but then alot more power usage meen less battery life or much larger battery then adds more weight i found out most like because of its the lastest operating system ,like wanting the lastest car or ? what happen when windows 8 come out i guess windows 7 nobody will like,and then windows 9 the same thing and so on,just so microsoft can make money by adding a feature if you look at all the professional robots on the markets made by the best robot engineers will not see them using a windows 7 or 64 bit and companies knows about windows 7,so ask your self why they not using it,doesnt cost more money to add it
#17
i found WINDOWS VISTA works great too,and there is still much support to it it does draw little more current then WINDOWS XP PRO much not much and close to WINDOWS 7 but still WINDOWS 7 DRAWS THE MOST CURRENT,simple test if you have windows xp pro or vista to compare current to windows 7 ,have 2 drives one with windows xp pro or vista,one with windows 7 in 32 bit mode,and if using 64 bit mode use that one and have a current meter hook up to 12 dc to dc converter so you can check idle current,min program current all programs running current on both operating systems,for speed test there are some programs out there that are free
if any ever see a big robot company that uses windows 7 let me know love to see it (link)
