Sabertooth Kangaroo icon Sabertooth Kangaroo — Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup. Try it →
Programing  Jd
I know this must be easy but I just can't find the right settings. I want JD to just see something moving and respond with speech. I also want JD to see a color and not get confused with movement and announce it. Can these both be run at the same time? Is there and activity to help with this movement recognition? Thanks All Ron
rr
preveous version made pic brighter.jezus
#50
@nomad maybe in your world it did, but sorry the control has always worked the way i described... If you don't believe me the click on the ? for more info....
#51
Richard check your control line its different than the one I said to use. I know yours works but the one they say to use in the video is different. Thanks Ron
#52
Actually, you need to forget that script. As I said, the Activity is outdated. Nonetheless, let's work with it one more time before leaving it
Okay, looks like you have a mistake in the first line. There is a space in there that needs to be removed.
#                          Remove this space
  ControlCommand ("Auto Position ", AutoPositionAction, "Point" )
Spaces count. Once you get rid of the space between Auto Position and the quote mark it should work. I'm assuming you don't have those line numbers you show in post #49 actually in the script. Also in order to test the script itself, a Sleep instruction should be added for the moment.
So, erase whatever you have in the script now and copy and paste the following lines into it:
ControlCommand ("Auto Position", AutoPositionAction, "Point" )
sayezbWait (" I see a" + $CameraObjectColor)
Sleep(3000)
Stop()
Then click the "Start" button on the script. It should point for a couple of seconds and say "I see", then straighten up.
If you like you can test it with the "Tracking" feature. As I said though, we will need to get past this and move on to how it should be now and get it working that way.
Try that and let me know how it went.
WBS00001
thanks i give it a try
#54
WBS00001
Perfect! You used the line they used and it worked. Not because I had a space as I didn't in the program. Originally I clicked on that script so it was right. The problem seemed to be the sleep(3000). Thanks very much! We have been going nuts getting people to see the problem which will probably only bother a new comer trying to follow the directions. This discussion on this has gone on for 3 or 4 days and NO ONE WOULD CHECK IT! THANKS I'M NOT NUTS! The new line they use works but the arm stays up when it points than goes down when it sees a color and goes up again and stays up until another color, repeat. Lets move on! Fantastic! Ron
i used one color and sleep(2000) works perfect. as for the multicolor i cant test cause i have bad lightning.
#56
Sorry to be so late replying. Very glad to hear that things are working now. The introduction of the Sleep instruction as a solution was somewhat inadvertent on my part, but hey, whatever works, right?:)
Let me know if there is anything else on this you need assistance with as you continue on.
