EZB Connections icon EZB Connections — Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices. Try it →
#17
@Sipddy1.
Nomad has given you some good advice, but in case you haven't seen it, I've posted a video below from the ARC Manual that explains the "Auto Positioner" control very well, and goes through how to add frames, actions, and to make a sequence which may hopefully help you further. It also shows you how to add a script to your action/sequence's. :)
