Personality Forge icon Personality Forge — Adds a Personality Forge chatbot to ARC, giving memory, emotions, AIScript dialogue, persistent conversation IDs and speech/chat integration via API. Try it →
Greece
Proplem With Firmware Update
Good afternoon DJ. Sures.
My name is SAKIS . I have the ez-b kit about 5 month. I have a problem with the update firmware V6.5, I did the steps to up date but i can't . This is the message that i saw when i try to update.........
Attempting connection to COM18 EZ-B reports EZ-B Firmware V6.5 Connected T+NAMEsakissending ping sending ping sending bootloader Failed to load bootloader! Have you selected the correct EZ-B COM port? Use the Help menu option to view the online help and watch a video demonstration.
PLEASE HELP ME. REGARDS SAKIS FROM GREECE.
confused
New Zealand
Hi sakis33 are you absolutely sure it's not a COMS related issue?
I discovered the exact same thing when I connected my EZ-B to the wrong COM port on my desktop PC when doing the previous update.
I even received the same confused 'old version' alert you did.
So I made sure nothing was connected to my EZ-B and tried again but still nothing!
So I had a look through the system manager to find which COMS post I need to connect to and discovered I had a COM10 listed as incoming and COM11 as out going...
(I had been earlier in the week working with setting up a few different Arduino boards for a school project.. A Duelaminovae, Leonardo and Freetronics Ether Mega to be specific).
Fortunately all was easily solved by swapping the COM port I had connected to and trying again.
I think it was just the way the system set up the bluetooth stack as the behaviour is different again when using my Toshiba laptop.
  • Wayne
A good way to test, is attempt a connection to the COM port you keep using - but do not power the EZ-B.
Hello and thanks for the replay :P
I look through the system manager to find the 2 coms , COM 6 Outgoing and COM 8Incoming with name sakis.
I use COM 6 to connect with EZ-B but i can't now.
How can i swapping the COM port and try again?
Thanks again for the already help
Regards Sakis
Ecuador
I think that is a problem of your computer... something wrong with the driver... try in another computer? this was the solution for me!:)
But I have two lap top pc and a I have the same connection problem for both of them .
#15
Simply select the correct COM port - do not try to swap them in software, or you will confuse Windows.
My solution is to visit Bluetooth Devices and remove the EZ-Robot device. Reboot your computer. Use the Tutorial section and follow the instruction on how to add the EZ-B to your computer. The tutorial will also demonstrate how to determine what COM port the EZ-B was detected.
Everything can be resolved by following the instructions provided to you:)
#16
Hello DJ again.
unfortunately i didn't found a solution.
I did the same "steps'...
I vist bluetooth Device and i remove the EZ-B Robot device, then i restart my PC .After that i connect the EZ-B to my PC with the Bluetooth with two ports com 16, com17 , i use the lower com16 . When i try to connect with ARC software i saw the same message confused
I have the problem wen i try to connect the mp3 trigger v2 , i don't know if mp3 trigger created the problem
