Augmented Reality icon Augmented Reality — Overlay PNG/JPG images in real-time onto detected objects, faces, colors or glyphs using ARC Camera tracking; attach, preview, detach. Try it →
Resolved Resolved by Jeremie!
Putting Jd Case Backtogether
What is the trick to putting the case of the body back together for JD? I took it apart to lengthen the charging wires to the battery and it won't fit back together. The shoulder servers are in place, I know the battery goes in the bottom, but the battery cable where does it lay inside the case?
this can be helpfull
No, it's really not helpful at all. I've seen that picture and the lesson.
I understand how it goes back together, I know it's all suppose to shove back in there, but it's not fitting because of the battery connection. I don't know where it's support to lay inside the body.
if you look at the pic,the connector come there where the hole of the speaker sits.
Is the connector suppose to fit in-between the bottom of the servers and the battery? It won't fit otherwise.
no above the batt,then you see it in front hole speaker
There is not enough room for it sit there.
I don't know if these will help Justin, but here's a few pics taken from the JD tutorials. Maybe you could figure it out from these...
I hope they help and you figure it out. If not could you post a picture of where you're at so far, and so we could see your battery extention?
Steve.
i found this pic and you see the tip of the connector
i know the wires lying close ontop eachother
