ADC Graph icon ADC Graph — Historical ADC graph and numeric readout (0-255) for 0-3.3/5V inputs; configurable board/port, sample interval, color, and pause for ezb controllers. Try it →
Pwm Control In Scripts
Hi DJ,
I am starting to use the PWM control on my H-bridge. The control itself works GREAT. What I need to do now is to get it into my movement scripts so i can change the speed of LEGION. I found out that I can use the Servo(DX,XX) and it works....Is this the script command I should be using? If so the problem is that it only limits to 75 and the range of the PWM control is through 233. I need more PWM to get my speed going on my H-Bridge.
Not sure if the right answer is maybe a new script command like PWM(DX,XXX) simply so folks don't overdrive normal servos.....
quick note: Wanted to ask if the VBScript function was going to be ready soon?
Thanks for your time DJ.......hope you are doing well!
v/r
Kevin
DJ, Not sure if this slipped off the panel too fast or not......any chance this might be in the new update?
thanks much...new update looks SWEET!
v/r
Kevin
it's in the next release:)
