Live Stream Receiver icon Live Stream Receiver — Play live web video and audio streams inside ARC from Chrome/Firefox, streaming directly to ARC camera control; network configuration may be needed. Try it →
Italy
QR Code with blockly
QR Code With Blockly
Hi! Using Blockly I can't find a "Wait for QR Code" block similar to the one present for glyphs.
I was able to find the function through javascript to get the wait for a new QR code but from Blockly I can't find the block. can you help me?
Is glyph recognition much better than QRCode? Can additional glyphs be added?
Thanks!
JD Humanoid by EZ-Robot
Create customizable QR codes for ARC, display/scan via Camera Control, trigger scripts on recognition and save decoded text to variables.
#1   — Edited
Thanks for the answer and the links but I wanted to understand how:
Add "wait for QR code" to blockly Increase the number of legible glyphs
Anyway I modified the ARC Blockly to have the block that was missing, now it seems to work
#3   — Edited
Up above, I showed how to "wait" in Blockly - when you look at the java tab, you get  -   Audio.sayWait(("I am reading " + CameraQRCode));  or  Audio.sayEZBWait(("I am reading " + CameraQRCode));
I see under the camera control "Wait For Glyph", but I don't see "Wait For QRCode", where did you get that?
Great, so you got it working?
EzAng
Yes, It works, sometimes the reading gets stuck but I think it's a QR problem. I have seen that with glyphs it works much better, besides the 4 where can I generate others?
#5   — Edited
Yes I had already seen your links! but QR codes don't work via App and reading the glyph is faster
thanks!
#7   — Edited
ok, if that is what you want to do.
I simply use this code and it works:
or you can use SayEZB(wait)  in the blocky program for your robot to speak
But is you want to use the 4 glyphs, that is fine, that is up to you my friend,
Have a good day,
EzAng
