Intel Realsense D435i icon Intel Realsense D435i — Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry. Try it →
Qr Code Reading , Feature Request
I apologize if this is already a feature hidden somewhere in script ,but I could not find it. General home navigation is easy using a Cam pointed at the ceiling , as the cam rolls under QR codes it reads them. However the QR code reader can decipher the code at any angle or even upside down. It would be fantastic if a there was a reading for the angle of rotation the QR code is when it is read. Like 0 degrees , 90 degrees or whatever. Even just 16 positions would be great so that the robot reads the code then also reads orientation it is facing as well. Simple fix. The other option is a electronic compass , but QR code read angle would be fantastic. Thanks
The EZ robot gyro will allow you to make precise turns with your bot and maybe even orientation when used with the ez accelerometer as well...
