Hello Forum from Greece
I need your help about BLINKM.
I want to write a script but i can't, i found the script command:
I2CWrite(0,0x09,?) What is the correct command?
I want to use BLINKM, when it found a red object then lights Red.
Movement Joystick
— Analog joystick UI to control any ARC movement panel via mouse/touch-configurable dead zone, max speed, center-reset for smooth robot motion
Section 3 of the datasheet covers the commands.
Looking at it you need to use;
Thanks Rich for the replay. It works, I am going to read the data sheet
Thanks again.
Hello forum, I am confused confused with BLINKM
I wrote this code
I2CWrite(0,0x09,n,0xff,0x00,0x00) for red color, but when i run the code i saw this message
Start 1: I2CWrite(0,0x09,n,0xff,0x00,0x000)
I did somethig wrong?
"I did the right connection with the controller".
The EZ-Script syntax changed a few weeks/months ago. Any text must be in quotes.
Try
or try converting the ascii to hex with
Ok
I didn't know that
Thanks Rich I am going to try
Yes , the change is "n" .
