Voice Activity Detection icon Voice Activity Detection — Real-time microphone VAD using FFT to detect speech start/end and trigger scripts, with live level graph and sensitivity tuning Try it →
Question About The L298n H-Bridge Motor Driver.
Hello. Currently as of a recent project I'm working on, I will need to obtain the L298N H-Bridge Motor Driver Shield. One question that I am concerned with; is it possible so that when an ultrasonic sensor on the EZ-Board detects an obstacle in the way, will the H-Bridge allow pager vibrating motors to vibrate and stop when there is no objects detected through the ultrasonic sensor? Thanks.~RoboticsMaster
A great concept. I wouldn't have thought anyone here would imitate it (but if they do remember imitation is the greatest form of flattery:)).
I would recommend a combination of ultrasonic and ir sensors. Each has strengths and weaknesses based on the surface material and shape of the obstacle.
You also need to consider edge detection, and other than Lidar or really good video interpretation I don't have a good recommendation for that. The cane is used to detect the edge of stairs, sidewalks and train platforms as much as obstacles.
In the television program Covert Affairs, there is a blind character who uses a (purely fictional) handheld laser device instead of a cane. I could easily see something like that being used with sonar or ir sensors for better situational awareness. Have the vibration patterns change based on distance to the object pointed at rather than just on/off. if you build and patent this, I just want name credit. You can make all the money;)
ALan
