Roomba Tones icon Roomba Tones — Deprecated Roomba control; replaced by the iRobot Roomba Movement Panel for updated movement control. Try it →
Resolved Resolved by Rich!
Question On Script Modification
So I am looking to modify this script that was on the cloud (thanks btw), however I am a little stuck... I am using the sabertooth Movement Panel ... so the the speed and turn times ect... dont match up (i know it not currently set that way but the commands are totally different with sabertooth).. Any thoughts on how to modify this for sabertooth ?
Ping Object Avoidance
Using Ultra Sonic Ping Sensor on servo for avoidance
Version 1.1.1
Configuration Settings
This script assumes the following ports;
Trig Port = D0
Echo Port = D1
Sweep servo = D2
Adjust values below for movement control
$reverseturn = 1 # Reverse before turn? 0 = no, 1 = yes $maxdistance = 30 # Change for maximum distance from object before avoiding in units $boxedindistance = 20 # Change for maximum distance for boxed in detection $turnamount = 500 # Change for how long to turn for in ms $reverseamount = 500 # Change for how long to reverse for in ms (if applicable) $movementspeed = 255 # Change for movement speed $slowturn = 127 # Change for slow turn speed
Adjust values below for sweep configuration
$sweepmin = 10 # Change for min limit $sweepmax = 90 # Change for max limit $sweepservodelay = 500 # Change for delay between sweep servo movements and readings
Testing Options
$testmode = 0 # Change to 1 if testing without PING sensor
Do not adjust these values
$sweepcenter = $sweepmin+$sweepmax
$sweepcenter = $sweepcenter/2
$sweepcenter = Round((($sweepmin+$sweepmax)/2),0) $sweepprevious = $sweepmax # Do not change $sweepcurrent = $sweepcenter # Do not change $SweepErrorFlag = 0 # Do not change $BoxedInErrorFlag = 0 # Do not change $BoxedInRun = 0 # Do not change $SweepCenterRun = 0 # Do not change $EscapeRun = 0 # Do not change $ScriptErrorFlag = 0 # Do not change $isboxedin = 0 # Do not change $penultimatemove = "none" $lastmove = "none"
That's a very old version of that script. I've since uploaded an alpha of my latest version (it's alpha as I haven't physically tested it but know others have tried it).
It's written better, more modular, so that it can be adjusted to suit your requirements.
Download it here. More info on it is here (including my marked up copies of the original scripts I wrote). It should be enough to point you in the general direction.
If you get stuck with any part of it give me a shout (but try to figure it out yourself, it's more rewarding that way).
Used in conjunction with my sabertooth ramping script it should work pretty well. Click my name to check my cloud projects, it's in there somewhere (amongst a few other examples)
