Question Using Tablet Camera Using ARC
I having a problem using the camera on my Windows 8.1 tablet. I get this error: Object recognition initialized Error initializing Camera: System.Runtime.InteropServices.ComException (0x80004004):Error HRESULT E_FAIL has been returned from call to a COM component.
I get the same error using either the front or rear facing camera...I have the latest ARC version 2016.01.06.00
#33
I had the same results as David trying to compile under VS2013. The SDK is the VS2010 one, and I don't have that version (I still have 2008, but didn't try that).
DJ, If you think it would help, I could loan you my Acer W3 for a while so you can maybe figure out what is going on. Not sure how we do that without needing to pay customs when shipping it back and forth between US and Canada.
I don't particularly care that the cameras don't work for me because the robot I will be putting it in won't need a camera at the location the tablet will be, but a lot of EZ-B users use this tablet, and if it would help solve the problem rb550f is having I would be more than happy to do something to assist (although he has a different tablet/camera, I assume it is the same issue since the error message is the same).
