Programming With Pictures icon Programming With Pictures — Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots. Try it →
Puerto Rico
Question With Assembly Instructions
hello,
I'm having problem with the building instructions for the basic models (JD, Roli and hexapod). When I open the program, I can't see the assembly instructions. How can i fix this? Since the program never recognized what robot I'm working with, there's nothing I can program... confused tired
You have either disabled the assembly instructions or disabled the "learn" popup. Visit the preferences menu and restore default settings.
Puerto Rico
I visited the preferences menu and it is as default. I uninstall the ARC and install it again but the problem continues. The problem is that the program never finds its library, I also try sync in the library and it downloaded the files but after that, I can't find them.
Esteban, After launching ARC, Click on Open, Examples and Open the Robot you are working on. You should now get a dialog box asking you if you want to open the Assembly Instructions Click Yes. With The EZ-Bits After you have Sync the Library Click on Manage and then Refresh Library. You should now see the EZ-Bits.
Richard Z.
