Waveshare Bus Servos icon Waveshare Bus Servos — Control Waveshare servos (TTL/RS485): set position & speed, release torque, read position. RTS option for converters; reverse-engineered protocol. Try it →
As Richard mentioned, you cannot delete a post, only edit it. You can click edit and delete what you wrote and write something else like "I deleted this post ad it's not relevent" or whatever you like.
In regards to the foot servo, can you not remove it from the foot casing to calibrate it? I though that you may be able to incase, for example, the servo ever needs replacing.
Also, have you tried closing the project and restarting it to get rid of the error message? If not You could also start a new project and get the assembly instructions up again.
@Steve... good point... There are screws in the bottom of JD's feet for that very purpose... Besides they had to get the servo in there in the first place, right?
My thoughts exactly. By the way Fry... I mean Richard, loving the new avatar :P.
Singapore
It's better but it still doesn't work properly. Thks anyway. Seems defective.
@mpelletier
No problem. Just to confirm, did you manage to remove the servo from the foot and calibrate it then? The only thing I can suggest then is change the servo position values for the unaligned foot servo for its standing, walking, dancing scripts ect, so that it straightens up and does what it should.
Or if you really do think it's deffevtive, maybe use the Contact us link and file a warrenty claim for a replacement foot.
