Horizontal Servo icon Horizontal Servo — Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert. Try it →
Question With Initialization Of Jd Robot Servo Are Not All Present
Hello, I received my jd ez-robot yesterday, this morning I rode the robot according to the proposed tutorials. It is connected in ARC as requested and that's when I have problems. All the servos are connected but when I go into project-configure, I realize that not all servos are visible in the interface. I also find that when I set a servo on the software, it is another that moves.j also have the two servos of the left foot and the left ankle that are blocked. Moreover I did not want to insist but there is a smell of burnt somewhere, so I cut the current directly. I say that this is the first start and that I have scrupulously respected all the instructions. I am going to attach to this mail, a screen printing of the console of adjustment of the servos and a photo of the reaction of the robot when I connect it via the function connect of ARC . Needless to say I am already a bit surprised at the reaction of the robot and I hope nothing is burnt or damaged. Can you help me please JD.comment test the servos one behind the other to find out if they are all operational? How to unlock the two servos that look blocked without breaking them? I have a servo tester for modelist, maybe it can help me to center all the servos avnt to redo the assembly?
Can you help me please ?
A big thanks in advance Olivier:(
stress
#17
Hello to all of you, I would like to apologize first because DJ sure to give the right explanation, I have actually done the calibration of all the servos, but not according to the tutorial of the site because I forgot this part And so I calibrate with a servo regulator. Which is not the right way, so I am totally at fault on that and I apologize DJ. It was Patrick (nomad 6r) who put me on the track, indeed he told me that there was a calibration and fine tuning and that it was two different things. So I reconvened this morning and I followed everything and confirmed this time the lessons I had not done. I disassembled and replaced the two servos that had burned and everything reassembled. And there are friends ! This time my jd lights up without force and I was able to start creating the profile for the servos and everything works normally. I had to stop during the creation of the profile because my battery is empty;). I will then charge the battery and finish the end of the profile for the servos. Dj, I will recommend servos this morning, to replace the two I grilled. I still wanted to apologize for my mistake and thank you all for your kindness and availability. EZrobot is professionalism to 100 percent, thank you again friends.
Patrick, I propose to maintain our skype of 11:00 am if it is always ok for you. I am a beginner in ezrobot and it would be nice to discuss with you the JD and its possibiltes.
Br Oliver;
hi oliver
i saw the gap in your text about calibration. am still doing calibrations today.esspecially the fine tuning. i can do calibration,make motion,or eye movement show you a few things in ARC,but for for diff stuff best to post on, the forum here.
tip after using the robot let him cool off for 30 min before charging. after charging again let the batt cool off for 30 min your batt will last longer
#19
Hi Patrick,
Ok , i have just one little question, when i have the screen for configure profile, all etiquettes of servo are not centred on the screen ,i join a printscreen, it's possible to align this labels on the screen ?
Thx you very much
Oliver:)
@skullofcob What is your screen resolution set at?
hi Richard R
thanks for helping.i was thinking about the resolution too. i think oliver still sleeping,he's not on skype.
#22
Hi all,
Good job, i'm on my laptop and it's 16/9 screen, i have change my resolution and now it's ok
definitivly, you are the bests ,thanks Patrick and Richard;))
Tomorow i'll start to learn with my JD, i 'll send to you a resume of my new adventure;)))
best regards
oliver;)
good work oliver.then you dont need skype session.
