Spain
Question With Speech Recognition On Windows 8
Sorry, but my English is not very good I have a problem with the "Speech Recognition" (I work half)
I have installed the "EZ-Builder" Version on a PC with Windows 8 I put a control "Speech Recognition" with the following parameters Enable Phrase: "Listen" Enable Cmd: say ("Listening") Disable Phrase: "Silence" Disable Cmd: say ("not listening")
Phrase Comand One Say ("one") Two Say ("two")
when I say "Listen," the computer says "listening" when I say "Silence", the computer says "not listening"
but however, when I say any command (one, two), the computer does not recognize, (only work enable phrase and disable phrase)
(I have Windows 8 in Spanish and actually the examples I have phrases done in Spanish )
Thanks in advanced
Make the phrase longer. I.E. "Robot One" (or whatever the Spanish is for that, sorry all I know in Spanish is how to order beer)
I tried it with longer sentences, and does not work. 8(
however the phrases put on "Enable" and "Disable" working perfectly.
I think ,must be a software bug, or speech a problem with speech Recognition in Spanish, because I've changed the language on my computer for U.S. English, and I have run the commands (in English of course) perfectly.
Spain
Xiscop Hello, I have windows 7 and I have exactly the same problem as you, only recognizes the phrases "Enable Phrase" and "disable phrase". How have you changed the language to U.S. English? I tried but did not succeed. Greetings.
Hello R2D2 Here's how I did in Windows 8 on Windows 7 suppose to be similar You must go to control panel add language "English U.S.", and you should put it as default language and Reboot, you must also go to the "Speech Recognition", and you will the 2 engines "Speech Recognition", one in your language and another on the "English U.S." you must select "English U.S.".
 I would like the EZ team, find a solution, so we can enjoy the voice recognition in our language (Spanish in my case).
It appears to be a small incompatibility of ARC, the language in both windows 7 and windows 8 [b]must be a problem with the control "speech recognition"[b] only with list of commands because the voice recognition works well with "prase enable" and "phrase disable"
We wait anxiously for the new version of ARC or a patch to correct this issue.
Thanks in advance thank you all for your efforts.
Hi,
I am not sure that it is an ARC issue. I use Speech Recognition in french (in windows8) and everything works fine. However, you should know that I had to train a lot in windows to begin to have some confidence in ARC...
Another thing to have in mind is that if you configure speech recognition in your own language, you should stop using english words, as they will not be correctly recognized anymore.
And finally, the quality of your microphone, and its settings, are important too.
Hope you will find a solution which works for you...
Some data
If I put the windows with U.S. English language, Recognition (In English of course) works correctly (as expected) both "prhase enable" and "disable prase" and lists of phrases for commands. (Although for that I must remove all other languages, and that if multiple simultaneous languages will mess and fails)
If I put the windows with Spanish language (deleting other languages) Recognition (in Spanish of course), only works properly with "phrase enable" and "disable phrase" however the list of commands does not recognize any, (and not by quality or by training, nor adequate words etc. ...), I think that loads default U.S. English grammar
In addition to loading control "Speech Recognition", in the Debug window I get:
The Desired culture (en-US) is not installed on this machine. We will load Culture: "es-ES" Loaded successfully speech recognition
Otherwise the pandora bot recognizes all dictation text in Spanish
It seems that wrong is the list "of commands" of the "Speech Recognition" and NOT voice recognition itself.
sorry for my English. Perhaps the title of the post should be: problems with speech recognition in other languages??.
