Hi,
I just received my JD but can not connect it to the WIFI with my HP computer. To see if it was an issue with the EZ-B I tried to connect it to my Mac Air and it connected. Does anyone know what the issue could be?
EZB Connections
— Add and manage up to 255 EZ-B I/O controller connections in ARC, select COM/IP ports or device addresses to connect or remove devices.
Hi,
Thanks everyone for your help on the HP issue. I have tried two different Wifi USB's with no luck. Jeremie, if you could make that video or explain to me about turning off my Wifi on my computer, maybe I can get my Netgear Wifi USB working. Next, I am going to a different computer that will not be an HP! I see with all of the questions on calibrating servos that I have a lot to learn once I get JD working! One day I will succeed! My computer has Windows 8.1 & 64 bit which I wished I hadn't bought. One USB says it's compatiable with Windows 8.1 Pro but not Windows 8.1. I want to thank all of the ez- robot employees because I know they are working around the clock to get everyones purchase working.
@michaeic I will make a video in the am. how disable the hp nic's. and use the usb wifi with ARC.
i have an hp envy 23 touchsmart pc, running windows 8.1 64bits os.
j
@jdebay.... I have the exact same 23" touchsmart HP as you without any connection issues whatsoever...
Edit Mine is actually a Pavilion 23
hmmm Maybe both you guys, @jdebay and @Richard R, can use the ARC diagnostic tool (under controls -> General) and share your WiFi Adapter diagnostics and we can compare!
Here you go Jeremie... (Actually my PC is a HP Pavilion 23) I have 5 ezb4 boards all connect flawlessly in wp or client mode... I have not experienced any disconnects that I didn't cause myself....
Start Menu Arduino CyberLink YouCam CyberLink Media Suite 10 CyberLink Power2Go 8 HP SimplePass Cyberlink PhotoDirector CyberLink PowerDirector 10 CyberLink PowerDVD 12 Pinger CyberLink YouCam HP Customer Experience Enhancements CereVoice SAPI CereVoice William 3.1.0 Evernote v. 5.1.1 Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 CyberLink Media Suite 10 CyberLink Power2Go 8 Cyberlink PhotoDirector Recovery Manager Realtek Card Reader Intel(R) Management Engine Components Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.51106 Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.51106 Hewlett-Packard ACLM.NET v1.2.2.3 Microsoft Visual C++ 2005 Redistributable HP Documentation Microsoft Visual C++ 2005 Redistributable Realtek Ethernet Controller Driver HP Support Assistant Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.51106 Microsoft Office Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Pinger CyberLink PowerDirector 10 HP Support Information CyberLink PowerDVD 12 EZ-Builder Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.51106 Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Intel(R) Processor Graphics Realtek High Definition Audio Driver Energy Star Arduino CyberLink YouCam CyberLink Media Suite 10 CyberLink Power2Go 8 HP SimplePass Cyberlink PhotoDirector CyberLink PowerDirector 10 CyberLink PowerDVD 12 Pinger CyberLink YouCam HP Customer Experience Enhancements CereVoice SAPI CereVoice William 3.1.0 Evernote v. 5.1.1 Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.4148 CyberLink Media Suite 10 CyberLink Power2Go 8 Cyberlink PhotoDirector Recovery Manager Realtek Card Reader Intel(R) Management Engine Components Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.51106 Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.51106 Hewlett-Packard ACLM.NET v1.2.2.3 Microsoft Visual C++ 2005 Redistributable HP Documentation Microsoft Visual C++ 2005 Redistributable Realtek Ethernet Controller Driver HP Support Assistant Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.51106 Microsoft Office Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.17 Pinger CyberLink PowerDirector 10 HP Support Information CyberLink PowerDVD 12 EZ-Builder Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.51106 Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 Intel(R) Processor Graphics Realtek High Definition Audio Driver Energy Star
Win32_NetworkAdapter
Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000000] Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter DeviceID = 0 GUID = {292B1C34-3949-4D42-8DED-1C369E14C38C} Index = 0 Installed = True InterfaceIndex = 3 MACAddress = B8:EE:65:77:22:04 Manufacturer = Broadcom MaxNumberControlled = 0 Name = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_14E4&DEV_4359&SUBSYS_2135103C&REV_00\000065FFFF77B8EE00 PowerManagementSupported = False ProductName = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter ServiceName = BCM43XX Speed = 182500000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Microsoft Kernel Debug Network Adapter Availability = 3 Caption = [00000001] Microsoft Kernel Debug Network Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Kernel Debug Network Adapter DeviceID = 1 Index = 1 Installed = True InterfaceIndex = 2 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Kernel Debug Network Adapter PhysicalAdapter = False PNPDeviceID = ROOT\KDNIC\0000 PowerManagementSupported = False ProductName = Microsoft Kernel Debug Network Adapter ServiceName = kdnic SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Realtek PCIe GBE Family Controller AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Realtek PCIe GBE Family Controller ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Realtek PCIe GBE Family Controller DeviceID = 2 GUID = {8657D8F8-0329-4673-992E-8DD3DC337701} Index = 2 Installed = True InterfaceIndex = 4 MACAddress = 00:25:AB:53:A6:87 Manufacturer = Realtek MaxNumberControlled = 0 Name = Realtek PCIe GBE Family Controller NetConnectionID = Ethernet NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = PCI\VEN_10EC&DEV_8168&SUBSYS_2B0D103C&REV_0C\0100000000AB250000 PowerManagementSupported = False ProductName = Realtek PCIe GBE Family Controller ServiceName = RTL8168 Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Microsoft Wi-Fi Direct Virtual Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000003] Microsoft Wi-Fi Direct Virtual Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Wi-Fi Direct Virtual Adapter DeviceID = 3 Index = 3 Installed = True InterfaceIndex = 5 MACAddress = BA:EE:65:77:22:04 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft Wi-Fi Direct Virtual Adapter PhysicalAdapter = False PNPDeviceID = {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP_WFD\5&2A57E707&0&01 PowerManagementSupported = False ProductName = Microsoft Wi-Fi Direct Virtual Adapter ServiceName = vwifimp Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Bluetooth Device (Personal Area Network) #2 AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000005] Bluetooth Device (Personal Area Network) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Bluetooth Device (Personal Area Network) DeviceID = 5 GUID = {96C778A9-808A-4217-BA67-7C82C4E49A62} Index = 5 Installed = True InterfaceIndex = 9 MACAddress = B8:EE:65:56:66:01 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Bluetooth Device (Personal Area Network) #2 NetConnectionID = Bluetooth Network Connection 2 NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = BTH\MS_BTHPAN\6&A1F97B8&0&2 PowerManagementSupported = False ProductName = Bluetooth Device (Personal Area Network) ServiceName = BthPan Speed = 3000000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Bluetooth Device (Personal Area Network) Availability = 3 Caption = [00000006] Bluetooth Device (Personal Area Network) CreationClassName = Win32_NetworkAdapter Description = Bluetooth Device (Personal Area Network) DeviceID = 6 Index = 6 Installed = True InterfaceIndex = 6 MaxNumberControlled = 0 Name = Bluetooth Device (Personal Area Network) PhysicalAdapter = False PowerManagementSupported = False ProductName = Bluetooth Device (Personal Area Network) SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Microsoft ISATAP Adapter AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000008] Microsoft ISATAP Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft ISATAP Adapter DeviceID = 8 Index = 8 Installed = True InterfaceIndex = 10 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Microsoft ISATAP Adapter PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\ISATAP_0 PowerManagementSupported = False ProductName = Microsoft ISATAP Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Teredo Tunneling Pseudo-Interface AdapterType = Tunnel AdapterTypeId = 15 Availability = 3 Caption = [00000009] Microsoft Teredo Tunneling Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Microsoft Teredo Tunneling Adapter DeviceID = 9 Index = 9 Installed = True InterfaceIndex = 11 Manufacturer = Microsoft MaxNumberControlled = 0 Name = Teredo Tunneling Pseudo-Interface PhysicalAdapter = False PNPDeviceID = SWD\IP_TUNNEL_VBUS\TEREDO_TUNNEL_DEVICE PowerManagementSupported = False ProductName = Microsoft Teredo Tunneling Adapter ServiceName = tunnel Speed = 100000 SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (SSTP) Availability = 3 Caption = [00000012] WAN Miniport (SSTP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (SSTP) DeviceID = 12 Index = 12 Installed = True InterfaceIndex = 12 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (SSTP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_SSTPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (SSTP) ServiceName = RasSstp SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (IKEv2) Availability = 3 Caption = [00000013] WAN Miniport (IKEv2) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IKEv2) DeviceID = 13 Index = 13 Installed = True InterfaceIndex = 13 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IKEv2) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_AGILEVPNMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (IKEv2) ServiceName = RasAgileVpn SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (PPPOE) Availability = 3 Caption = [00000014] WAN Miniport (PPPOE) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPPOE) DeviceID = 14 Index = 14 Installed = True InterfaceIndex = 14 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (PPPOE) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_PPPOEMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (PPPOE) ServiceName = RasPppoe SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (PPTP) Availability = 3 Caption = [00000015] WAN Miniport (PPTP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (PPTP) DeviceID = 15 Index = 15 Installed = True InterfaceIndex = 15 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (PPTP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_PPTPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (PPTP) ServiceName = PptpMiniport SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (L2TP) Availability = 3 Caption = [00000016] WAN Miniport (L2TP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (L2TP) DeviceID = 16 Index = 16 Installed = True InterfaceIndex = 16 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (L2TP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_L2TPMINIPORT PowerManagementSupported = False ProductName = WAN Miniport (L2TP) ServiceName = Rasl2tp SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (IP) Availability = 3 Caption = [00000017] WAN Miniport (IP) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IP) DeviceID = 17 Index = 17 Installed = True InterfaceIndex = 17 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IP) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANIP PowerManagementSupported = False ProductName = WAN Miniport (IP) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (IPv6) Availability = 3 Caption = [00000018] WAN Miniport (IPv6) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (IPv6) DeviceID = 18 Index = 18 Installed = True InterfaceIndex = 18 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (IPv6) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANIPV6 PowerManagementSupported = False ProductName = WAN Miniport (IPv6) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
WAN Miniport (Network Monitor) Availability = 3 Caption = [00000019] WAN Miniport (Network Monitor) ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = WAN Miniport (Network Monitor) DeviceID = 19 Index = 19 Installed = True InterfaceIndex = 19 Manufacturer = Microsoft MaxNumberControlled = 0 Name = WAN Miniport (Network Monitor) PhysicalAdapter = False PNPDeviceID = SWD\MSRRAS\MS_NDISWANBH PowerManagementSupported = False ProductName = WAN Miniport (Network Monitor) ServiceName = NdisWan SystemCreationClassName = Win32_ComputerSystem SystemName = ROBOT_PC TimeOfLastReset = 20140926074524.476935-240
Win32_NetworkAdapterConfiguration
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=0 Caption = [00000000] Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter DatabasePath = %SystemRoot%\System32\drivers\etc DefaultIPGateway = 192.168.225.1 Description = Broadcom BCM943228HMB 802.11abgn 2x2 Wi-Fi Adapter DHCPEnabled = True DHCPLeaseExpires = 20141012013130.000000-240 DHCPLeaseObtained = 20141011013130.000000-240 DHCPServer = 192.168.225.1 DNSDomainSuffixSearchOrder = DNSEnabledForWINSResolution = False DNSHostName = Robot_PC DNSServerSearchOrder = 192.168.225.1 DomainDNSRegistrationEnabled = False FullDNSRegistrationEnabled = True GatewayCostMetric = 0 Index = 0 InterfaceIndex = 3 IPAddress = 192.168.225.101 fe80::f054:47b0:8bc7:ee0e IPConnectionMetric = 25 IPEnabled = True IPFilterSecurityEnabled = False IPSecPermitIPProtocols = IPSecPermitTCPPorts = IPSecPermitUDPPorts = IPSubnet = 255.255.255.0 64 MACAddress = B8:EE:65:77:22:04 ServiceName = BCM43XX SettingID = {292B1C34-3949-4D42-8DED-1C369E14C38C} TcpipNetbiosOptions = 0 WINSEnableLMHostsLookup = True
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=1 Caption = [00000001] Microsoft Kernel Debug Network Adapter Description = Microsoft Kernel Debug Network Adapter DHCPEnabled = True Index = 1 InterfaceIndex = 2 IPEnabled = False ServiceName = kdnic SettingID = {8718928D-CBEB-45EA-A621-800A9249001D}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2 Caption = [00000002] Realtek PCIe GBE Family Controller Description = Realtek PCIe GBE Family Controller DHCPEnabled = True Index = 2 InterfaceIndex = 4 IPEnabled = False MACAddress = 00:25:AB:53:A6:87 ServiceName = RTL8168 SettingID = {8657D8F8-0329-4673-992E-8DD3DC337701}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=3 Caption = [00000003] Microsoft Wi-Fi Direct Virtual Adapter Description = Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled = True Index = 3 InterfaceIndex = 5 IPEnabled = False MACAddress = BA:EE:65:77:22:04 ServiceName = vwifimp SettingID = {185FEE05-0224-476B-B8EE-E745BDEFCCA2}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=5 Caption = [00000005] Bluetooth Device (Personal Area Network) Description = Bluetooth Device (Personal Area Network) DHCPEnabled = True Index = 5 InterfaceIndex = 9 IPEnabled = False MACAddress = B8:EE:65:56:66:01 ServiceName = BthPan SettingID = {96C778A9-808A-4217-BA67-7C82C4E49A62}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=6 Caption = [00000006] Bluetooth Device (Personal Area Network) Description = Bluetooth Device (Personal Area Network) DHCPEnabled = True Index = 6 InterfaceIndex = 6 IPEnabled = False ServiceName = BthPan SettingID = {01DDD903-BCFD-46C7-B5A2-896E34590F89}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=8 Caption = [00000008] Microsoft ISATAP Adapter Description = Microsoft ISATAP Adapter DHCPEnabled = False Index = 8 InterfaceIndex = 10 IPEnabled = False ServiceName = tunnel SettingID = {4CF4DEA2-B12A-4015-B1FC-31547E9D4F5B}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=9 Caption = [00000009] Microsoft Teredo Tunneling Adapter Description = Microsoft Teredo Tunneling Adapter DHCPEnabled = False Index = 9 InterfaceIndex = 11 IPEnabled = False ServiceName = tunnel SettingID = {0C9A0A33-1D70-45CD-80C3-DB79C6C5F28E}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=12 Caption = [00000012] WAN Miniport (SSTP) Description = WAN Miniport (SSTP) DHCPEnabled = False Index = 12 InterfaceIndex = 12 IPEnabled = False ServiceName = RasSstp SettingID =
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=13 Caption = [00000013] WAN Miniport (IKEv2) Description = WAN Miniport (IKEv2) DHCPEnabled = False Index = 13 InterfaceIndex = 13 IPEnabled = False ServiceName = RasAgileVpn SettingID = {7703E127-FE4D-4103-A6C5-382819A7F53D}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=14 Caption = [00000014] WAN Miniport (PPPOE) Description = WAN Miniport (PPPOE) DHCPEnabled = False Index = 14 InterfaceIndex = 14 IPEnabled = False ServiceName = RasPppoe SettingID =
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=15 Caption = [00000015] WAN Miniport (PPTP) Description = WAN Miniport (PPTP) DHCPEnabled = False Index = 15 InterfaceIndex = 15 IPEnabled = False ServiceName = PptpMiniport SettingID = {4A5CB0DD-7D62-4E60-90E5-F8CE4812F1B2}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=16 Caption = [00000016] WAN Miniport (L2TP) Description = WAN Miniport (L2TP) DHCPEnabled = False Index = 16 InterfaceIndex = 16 IPEnabled = False ServiceName = Rasl2tp SettingID = {48C0E5DE-E3B8-43C2-87E4-CC52377B36D4}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=17 Caption = [00000017] WAN Miniport (IP) Description = WAN Miniport (IP) DHCPEnabled = False Index = 17 InterfaceIndex = 17 IPEnabled = False ServiceName = NdisWan SettingID = {83B74FE1-C658-44DA-AEF0-D47A7D34325B}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=18 Caption = [00000018] WAN Miniport (IPv6) Description = WAN Miniport (IPv6) DHCPEnabled = False Index = 18 InterfaceIndex = 18 IPEnabled = False ServiceName = NdisWan SettingID = {9AA117A0-689C-4CCA-9F66-3EAD6F52E0F3}
\ROBOT_PC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=19 Caption = [00000019] WAN Miniport (Network Monitor) Description = WAN Miniport (Network Monitor) DHCPEnabled = False Index = 19 InterfaceIndex = 19 IPEnabled = False ServiceName = NdisWan SettingID =
ROBOT_PC AdminPasswordStatus = 0 AutomaticManagedPagefile = True AutomaticResetBootOption = True AutomaticResetCapability = True BootROMSupported = True BootupState = Normal boot Caption = ROBOT_PC ChassisBootupState = 3 CreationClassName = Win32_ComputerSystem CurrentTimeZone = -240 DaylightInEffect = True Description = AT/AT COMPATIBLE DNSHostName = Robot_PC Domain = WORKGROUP DomainRole = 0 EnableDaylightSavingsTime = True FrontPanelResetStatus = 0 HypervisorPresent = False InfraredSupported = False KeyboardPasswordStatus = 0 Manufacturer = Hewlett-Packard Model = 23-p039 Name = ROBOT_PC NetworkServerModeEnabled = True NumberOfLogicalProcessors = 4 NumberOfProcessors = 1 OEMStringArray = FBYTE#3E3K3N3Q4C4h5c666J6S6Z6b7B7K7M7R7S7W7s8FaBapaqasauazb3bPbS bhbpcbcect.F3;BUILDID#14AM2ARA602#SABL#DABL;
PartOfDomain = False PauseAfterReset = -1 PCSystemType = 1 PCSystemTypeEx = 1 PowerOnPasswordStatus = 0 PowerState = 0 PowerSupplyState = 3 PrimaryOwnerName = [email protected] ResetCapability = 1 ResetCount = -1 ResetLimit = -1 Roles = LM_Workstation LM_Server NT Status = OK SystemType = x64-based PC ThermalState = 3 TotalPhysicalMemory = 8475103232 UserName = Robot_PC\ROBOT_PC\Richard WakeUpType = 6 Workgroup = WORKGROUP
Mine are in this topic
synthiam.com/Community/Questions/6437 J
@Richard R
We do not have the same hardware!
This is my WiFi
\TOUCHMEPC\root\cimv2:Win32_NetworkAdapterConfiguration.Index=2 Caption = [00000002] Ralink RT3290 802.11bgn Wi-Fi Adapter Description = Ralink RT3290 802.11bgn Wi-Fi Adapter DHCPEnabled = True Index = 2 InterfaceIndex = 4 IPEnabled = False MACAddress = A4:17:31:06:93:B7 ServiceName = netr28x SettingID = J
Maybe this will help? I compared my diagnostics with Richard's. I don't know what I am talking about but here was some differences. These were in the same order with Richard showing WiFi first & Mike showing Ethernet first.
Richard Mike Net Connection ID = WiFi Ethernet Net Connection Status = 2 2
Net Connection ID = Ethernet WiFi Net Connection Status = 7 2 Net Enabled = False True
Microsoft WiFi Direct Virtual Adapter Device ID = 3 7 Index = 3 7
mike Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter DeviceID = 2 GUID = Index = 2 Installed = True InterfaceIndex = 4 MACAddress = 24:FD:52:14:3A:E6 Manufacturer = Qualcomm Atheros Communications Inc. MaxNumberControlled = 0 Name = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 2 NetEnabled = True PhysicalAdapter = True PNPDeviceID = PCI\VEN_168C&DEV_0032&SUBSYS_1838103C&REV_01\4&AB30070&0&00E1 PowerManagementSupported = False ProductName = Qualcomm Atheros AR9485 802.11b/g/n WiFi Adapter ServiceName = athr Speed = 97500000 SystemCreationClassName = Win32_ComputerSystem SystemName = SKOAL TimeOfLastReset = 20140930092436.829396-300
rr Win32_NetworkAdapter
john Ralink RT3290 802.11bgn Wi-Fi Adapter AdapterType = Ethernet 802.3 AdapterTypeId = 0 Availability = 3 Caption = [00000002] Ralink RT3290 802.11bgn Wi-Fi Adapter ConfigManagerErrorCode = 0 ConfigManagerUserConfig = False CreationClassName = Win32_NetworkAdapter Description = Ralink RT3290 802.11bgn Wi-Fi Adapter DeviceID = 2 GUID = Index = 2 Installed = True InterfaceIndex = 4 MACAddress = A4:17:31:06:93:B7 Manufacturer = Ralink Technology, Corp. MaxNumberControlled = 0 Name = Ralink RT3290 802.11bgn Wi-Fi Adapter NetConnectionID = Wi-Fi NetConnectionStatus = 7 NetEnabled = False PhysicalAdapter = True PNPDeviceID = PCI\VEN_1814&DEV_3290&SUBSYS_18EC103C&REV_00\4&12E9EEF9&0&00E2 PowerManagementSupported = False ProductName = Ralink RT3290 802.11bgn Wi-Fi Adapter ServiceName = netr28x Speed = 9223372036854775807 SystemCreationClassName = Win32_ComputerSystem SystemName = TOUCHMEPC TimeOfLastReset = 20140927105616.498214-240
each of us has a different wifi that came with our hp, see above.
m
i added another usb wifi and got it working with ezb's
Again I am going to ASK do you want me to make an how to disable nic's Or not?
j
