Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Question On Amps Of Ezb Board
how many amps i can input to ezb board . iam running 12vdc at 2 amps battery pack now running 5 servo .but if i add more servo for arms ill have to add more amps to the board how much can it take any idears ,i know that theres 5 amp fuse on board will it blow if i go over that amp . thanks cory
ok guys ,i just hook up a 18v drill battery i hook up 10 servos to see if the board will power up . it def my 12volt battery pack is bad or its dont have milamps to power it up with 6 servos . i knew it was that iam right on that ...:D
