Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Resolved Resolved by Jeremie!
Questions With Brand New Ezb4
I have a problem with my brand new EZB4:
Basically what happens is:
  1. Connect the battery (charged)
  2. EZB starts blinking blue light
  3. No sound of connection/activation EZB
  4. Wifi connection with EZB in windows works
  5. Connecting in the EZB in the connection panel of the ARC does not work (see screenshot attached)
  6. If I do this procedure with my other EZB all works fine and a connection is made with ARC.
Attached to this thread you can see a screenshot of the code generated by ARC when trying to connect to the EZB. Here you can find also a video which I made to show what happens when I try to connect the EZB4 https://we.tl/3C4pRDRw8o
If anyone would have some advice or need more info on this problem? I will be happy to provide this. we.tl/3C4pRDRw8o
That looks like the same disconnect readout I was getting last month when a random spark blew my bottom board, replacement of the bottom fixed my EZB4.
'a defect on the bottom board' I think this could be right, sounds like logic. Strange on a brand new EZB. I will contact customer support. Thanks to everybody who looked into this thread! Well appreciated ;-)
Are the magnets attached to the bottom plastic shell? Or did the magnets fall off?
Please post a picture of the bottom plastic shell, thanks!
Hi Dj, Here's a picture of the bottom plastic shell. The magnets did not fall off. In the meanwhile I have received a new bottom part for my EZB and it works. Great service, great community! Appreciated! Thanks so much! grtz Seth
@jeremie, I have the same symptom as @bertino on my new EZb v4 no power up sounds, and no flashing blue light on bottom board... top board has flashing blue light
Magnets are in place
Regards, Frank
I'm sorry to hear that Frank, what are the circumstances around your troubles?
The LED on the bottom board should be solid Blue, can you confirm that it's on? Can you connect to your EZ-B still in ARC?
#15
@jeremie, This is a brand new unit and has no bottom board LED light showing at all nor any sound. All of my other EZ-B v4 units have been perfect
Here is what I see regarding the top LED
Power up - flashing blue Reset- blinks yellow while button is held then flashing blue Connect with AP mode- still flashing blue Set Client Mode & reset- flashing green Scan for EZ-B v4, found it, click- flashing green Click Connect, can't connect- still flashing green
No sound at all even though chimes are enabled and LED on bottom board never lights up
Thanks, Frank
#16
Thanks for troubleshooting that Frank,
Seeing as it's a brand new unit please contact Customer support under the product warranty section of our Contact Us page
