Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
RPLIDAR Script Data Not Updating
I am using the RPLIDAR skill in ARC. The scan view is working correctly and I can see real-time obstacles in the UI.
However, I cannot access usable scan statistics from scripts:
$LidarNearestDistance always returns 0 $LidarFurthestDistance always returns 0 Only angle-based values (degrees) appear to update in script variables
My questions:
Does this skill support exporting real-time scan data (nearest distance / furthest distance or full point cloud) to script-accessible global variables? If yes, what setting or mode must be enabled to activate this? If not, what is the intended method for implementing obstacle detection in scripts using this skill?
I am building a mobile robot (wheelchair platform) and need reliable obstacle detection for navigation. The LiDAR will be mounted centrally at ~80-90 cm height.
Estimate pose odometry from movement distance for robots without encoders, calibrated by speed. Suited for DIY navigation; pose drifts with lidar.
Rplidar by Slamtec
Slamtec Lidar driver for ARC; scans 360° and publishes distance data to NMS for mapping, obstacle avoidance, and navigation.
Yes - the RPLidar skill does expose scan data to ARC, but there’s an important distinction:
  • UI rendering of the scan can work even when
  • global variables for scan stats are not enabled the way you expect
What to check first
Open the RPLidar skill settings using the kebab menu (three lines in the top-right of the skill window) and look for:
  • Enable UI Scan Render - this only affects the display
  • Set variables with location data - this is the key option if you want scan points exported to variables
  • Use NMS - enable this only if another navigation skill needs the data through the Navigation Messaging System
If "Set variables with location data" is not checked, the skill may still render scans in the UI, but you won’t get the richer scan data in script-accessible globals.
About the variables you mentioned
The RPLidar skill can expose variables such as:
  • minimum distance
  • maximum distance
  • corresponding degrees
  • scan status
However, if $LidarNearestDistance and $LidarFurthestDistance are staying at 0, that usually means one of these is happening:
  1. Those are not the actual variable names used by the skill in your project
  2. The skill is not configured to publish variables
  3. You’re expecting full point-cloud access from globals, which this skill doesn’t provide directly
Intended method for obstacle detection
For obstacle detection in scripts, the usual approach is:
  • Use the RPLidar skill to detect obstacles
  • Use ControlCommand() or navigation skills to consume the scan data
  • Or use the NMS pipeline if you want autonomous navigation behavior
For a mobile robot / wheelchair platform, the recommended ARC architecture is:
  • RPLidar skill for scan acquisition
  • The Better Navigator or another NMS-compatible navigation skill for decision-making
  • Optional custom script to react to obstacle ranges or zones
If you need direct script logic
If your goal is simple obstacle detection, you usually don’t need a full point cloud in script. A better pattern is:
  • read the lidar’s published nearest obstacle values
  • define a danger threshold
  • stop or slow the robot when obstacles are too close
Example pattern:
var nearest = getVar("$LidarNearestDistance", 0);
if (nearest > 0 && nearest < 80) {
    Movement.stop();
If that variable never updates in your project, I’d recommend confirming the exact variable names in the RPLidar config page, since the skill may publish differently named globals depending on settings.
Important note for your build
Since this is a wheelchair platform, I’d strongly recommend not relying on a single sensor variable alone for safety-critical obstacle avoidance. Use:
  • lidar
  • physical bumpers / e-stop
  • conservative speed limits
  • a layered stop condition in ARC
Next step
Can you tell me:
  1. The exact variable names shown in the RPLidar configuration page
  2. Whether Set variables with location data is enabled
  3. Whether you are using NMS or just scripting directly
If you want, I can help you write a JavaScript obstacle-monitor script for ARC that uses the lidar data safely.
#2   — Edited
For your requirement, this robot skill will be useful. Having an array of all lidar ranges of the entire 360 range is not feasible for any usage outside of a SLAM or rendering system. For scripting like you want to do, rather than using The Better Navigator, you can use this.
Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan.
But you'd be reinventing the wheel if you're attempting way-point navigation because The Better Navigator uses professional-grade SLAM navigation algorithms for path planning, obstacle avoidance, and way-point navigation.
Hector SLAM navigation with NMS pose and obstacle data for room mapping, waypoints, and autonomous obstacle-avoiding routes.
Germany
Thank you for the detailed explanation and recommendations. I understand now that for my use case (simple obstacle avoidance, no waypoint navigation), using the NMS Navigation Data Grabber is likely the better approach compared to relying on limited global variables from the RPLidar skill. I will proceed with testing the NMS Navigation Data Grabber to retrieve distance data for specific angles or arcs and use that for obstacle detection logic. My LiDAR will be mounted centrally on a wheelchair platform at around 35-40 cm height, so I am aiming for reliable front-sector obstacle detection. Thank you again for the guidance - I will try this approach.
