Does the radar scan control work via the mobile interface or is it just scripting?
Thanks
EZ-B Settings
— Configures and pushes WiFi SSID, password, system name and channel to EZ-Robot EZ-B v4 from ARC; saves settings with project for quick redeploy.
Thanks
i didn see the radar in the app android.so am not sure it works on mobile.
radar
No. Its not an option and it would not work at this time. The mobile app only provides movement control, temp and voltage readings and microphone output (allowing you to speak through the EZ-B). Check out the Mobile App Introduction under the "Learn" section.
https://synthiam.com/Tutorials/Default.aspx?id=8
You could easily replicate the radar functions through EZ-Script which will work with the mobile app
Basically you just need a script that moves a servo from one position to the centre position to another position and back again, inbetween each movement check the Ping and act accordingly. This is pretty much the basis of my Ping Roam scripts, if you check the first version I wrote (it's in the cloud) it was basically a clone of the radar control.
@Rich, I would disagree to the extent that you would lose the visual feedback. If the goal is to make sure the robot can use the PING sonar, then I agree scripting the entire process is possible. But you would lose any visual indication of the RADAR effect in the mobile app, would you not?
Yes you would lose the visual effects but the functions could be scripted, i.e. scan only while moving forward, control movement panel, reverse before turn and scanning a greater area by using a moving servo. I didn't class the visuals as a function.
Thanks all for your responses
