EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Radar Scan/ping Sensor
Radar Scan/Ping Sensor
I watched the video tutorial of Dj on the radar scan and how to hook it up, I noticed he said always remember, negative is always in the center, did he make a mistake when he said that, or was that a different board? Also, I did that exact setup and I can't get my tamiya tank to respond(also, I set the settings real close to his), the servo scans like it's supposed to but it will not stop when it gets near anything, I put it on my bench on top of a stand so the tracks can run free and I would wave my hand in front of it and got absolutely no response, am I doing anything wrong? Please don't tell me I have a bad board.
I hate to sound dumb but when you say wifi, I have a wireless router but how do I connect to the rover through ARC? I've watched the tutorial but he says go to your wifi list, is he on a laptop or a desktop, can I do this from my desktop where I am wired to my router even though a I have a wireless router, my desktop isn' wireless, thats where i'm confused.
do you think network magic has something to do with it?
The PC that connects to the Rover will need to have WiFi. If your desktop is wired then it will not be able to connect to it. You connect to the Rover like you connect to your router. While connected you will not have access to the internet or your home LAN unless you have two WiFi cards/dongles.
you were right, my bad, lol
I usually am;) (I try not to post if I'm not entirely sure of myself). But I'm here to help so it's all good:)
I assume it's all sorted then?
Yes, it works perfectly, I soldered the wires to the sensor and went straight to the board with it, remember when I said I used jumpers, well, I guess you can't assume they are making contact even though they are plugged into the modular plugs, lesson learned, thanks a again.
